I have been updating my MC7304 boards via Linux (on Hummingboard Gate), and it seems that the command “fwdldarm” does not exit, even if it seems that the upgrade has finished and everything is ok.
INFO: Running with device in boot and hold mode
INFO: Path: /tmp/
INFO: Device Type( 0,1,2,3->9x00,9x15,9x30,G3K ): 1
Downloading Firmware…
<here I do ctrl+c to exit>
When I check manually from AT command I can see that the status is “SUCCESS”.
at!BCFWUPDATESTATUS
!BCFWUPDATESTATUS: SUCCESS
From dmesg printout I can see that the USB devices has been identified OK, and everything is fine.
But still, the command “fwdldarm” will continue printing it’s dots until I cancel it with crtl+c, and therefor I will never get the result code of the “fwdldarm”.
Anyone seen same kind of issues?
Regards,
Sebastian
