I wrote an application on a GL6100 modem that acts as a gateway between a TCP/ip software and a modbus RS-485 network.
Things works just fine. I have though some modbus related errors signaled by the TCP/IP software i’m using…incorrect readings and for that i made on the modem level CRC verification for both directions.
My question is how can i save some logs or something while the modem is in production, something like traces but that can be viewed after i disconnect the modem from the serial network…
Hope i made myself clear enough, thanks in advance…
Thanks…i thought also to write in flash some error identifiers…but i also though that maybe there an api specially for this…
Thanks for your reponse…i will implement it like this.
