Issue while starting legato 16.01.2 framework
#1
I am porting Legato framework 16.01.2 on to IMX6 Sabersd board. I have compiled framework using IMX6 toolchain and placed on the board.
Started framework by running “start” script from /mnt/legato, I could see “Could not set extended attribute. Operation not supported” while executing following commands.
xattr set security.SMACK64 "*" /dev/null xattr set security.SMACK64 "*" /dev/zero
Can you guide me to fix the error while executing xattr on /dev/null and /dev/zero.
#2
Alex Jiang is travelling today, so I’m quoting his response:
#3
After enabling kernel configuration as shown below, the issue was fixed.
security options -> Enable different security models : Simplified Mandatory Access Control Kernel support Default securitymodule(Simplified Mandatory Access Control)
