Io( ) function complete syntax
someone know all the string values to use the new version of io() function?
Online Help reports only digital input/output values:
“IO1”,“IO2”,…
specifically I’d like to know what are the constants for AD converter,but the complete list would be the best.
Thanks in advance,
Best regards.
A. Giuliani
Spei2000 s.r.l.
spei2000.it
ok,I have found an at command which shows the syntax I needed…
[hyper terminal]
at*e2io=?
*E2IO: (0-5),(“IO1”,“IO2”,“IO3”,“IO4”,“IO5”,“IO6”,“IO7”,“IO8”,“IO9”,“IO10”,"IO11
",“IO12”,“IO13”,“IO14”,“AD1”,“AD2”,“AD3”),(0,1)
hi
try to get a copy of latest AT command manual that will help you a lot with GR64 command syntax.
Asiri
csspl.com.au
