I need the information about the ARM processor in the Q2406B
I need the information about the ARM processor in the Q2406B,such as the clock, running speed(MIPS),the number of the bit and so on. And, how much are the memory and flash in the Q2406B?
Why do you need this information?
Open-AT doesn’t give you any access that would benefit from this information!
Isn’t that stated in the datasheet for the part?
I want to implement the algorithm on the Q2406B, so I need the information about the ARM processor in Q2406B, such as the clock(MHz),
running speed(MIPS), and the number of bit.
Please tell me, if you kown them. It’s important to me. Thanks!
What algorithm?
That will depend on the compiler you use - see your compiler manual, and choose whichever data type has the size, etc, that you require.
Or just used Wavecom’s “standard” definitions from wm_types.h
