# How to Erase Program and go to Factory Defaults
**URL:** <https://forum.sierrawireless.com/t/how-to-erase-program-and-go-to-factory-defaults/7950>\
**Category:** Legacy FX/FXT series\
**Created:** [May 14, 2015, 9:02am UTC](https://forum.sierrawireless.com/t/how-to-erase-program-and-go-to-factory-defaults/7950 "2015-05-14T09:02:42Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jupiter](https://avatars.discourse-cdn.com/v4/letter/j/53a042/32.png) [@Jupiter](https://forum.sierrawireless.com/u/Jupiter)\
**Post date:** [May 14, 2015, 9:02am UTC](https://forum.sierrawireless.com/t/how-to-erase-program-and-go-to-factory-defaults/7950/1 "2015-05-14T09:02:42Z")
</div>
Hi
I have GL6100 modems alredy programmed with an application. I want to delete everything to take it back to factory defaults. I’m using Developer Studio. How can I do it?
**Author:** ![awneil](https://avatars.discourse-cdn.com/v4/letter/a/49beb7/32.png) [@awneil](https://forum.sierrawireless.com/u/awneil)\
**Post date:** [May 14, 2015, 10:16am UTC](https://forum.sierrawireless.com/t/how-to-erase-program-and-go-to-factory-defaults/7950/2 "2015-05-14T10:16:47Z")
</div>
See ATZ and AT+WOPEN in the AT Commands manual
**Post date:** [May 19, 2015, 4:58pm UTC](https://forum.sierrawireless.com/t/how-to-erase-program-and-go-to-factory-defaults/7950/3 "2015-05-19T16:58:08Z")
</div>
Hi
I managed to erase the program with the at+wopen command, but now some basic features already present in new modems of this model are not available (eg. at+wipcfg gives an error)
**Author:** ![davidc](https://avatars.discourse-cdn.com/v4/letter/d/a183cd/32.png) [@davidc](https://forum.sierrawireless.com/u/davidc)\
**Post date:** [May 19, 2015, 9:11pm UTC](https://forum.sierrawireless.com/t/how-to-erase-program-and-go-to-factory-defaults/7950/4 "2015-05-19T21:11:53Z")
</div>
Hiya,
At+wipxxxx commands are part of an application that runs inside the modem, not built into the firmware. At+wopen has deleted this application as well as resetting the configuration. You will have to reload the Internet Application (wip library) into your modem using Dev Studio.
The application should be available as a .dwl file in your installation of dev studio.
Ciao, Dave
edit: Have a look for the file ‘ExtendedATApplication.dwl’ and use DS to download that onto your modem.
> Extended AT Application is the application which provides a set of AT commands for Internet service (Internet Application like), Location service (GPS)(with AirPrime XM0110 GPS module) and eCall In-Band Modem service. This application subscribes to +WIP AT commands, +GPS AT commands and +INBM AT Commands.
> Once the subscription function returns OK, it is possible to use +WIP AT commands as described in WIP AT Commands User Guide and +GPS AT commands as described in Location AT Commands Interface guide. +INBM AT Commands as described in eCall In-Band Modem AT Commands Interface guide
ciao, Dave
