# How to connect via qmi\_wwan on Ubuntu?
**URL:** <https://forum.sierrawireless.com/t/how-to-connect-via-qmi-wwan-on-ubuntu/7365>\
**Category:** MC/EM Series\
**Created:** [August 5, 2014, 7:42am UTC](https://forum.sierrawireless.com/t/how-to-connect-via-qmi-wwan-on-ubuntu/7365 "2014-08-05T07:42:25Z")\
**Showing post:** 1
**Author:** ![ljbade](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.sierrawireless.com/ljbade/32/1763_2.png) [@ljbade](https://forum.sierrawireless.com/u/ljbade)\
**Post date:** [August 5, 2014, 7:42am UTC](https://forum.sierrawireless.com/t/how-to-connect-via-qmi-wwan-on-ubuntu/7365/1 "2014-08-05T07:42:25Z")
I just received a new MC7304 card to put into my Ubuntu 14.04 Server. I am replacing a USB Huawei stick which worked reasonably well via wvdial and PPP.
I managed to get the MC7304 connected via wvdial and PPP after setting the correct /dev/ttyUSB2. I am now looking at using the QMI interface since it is supposed to be faster.
I installed the libqmi-utils package to get qmicli and qmi-network.
I then followed a gist I found on how to conenct via this on Debian. However after connecting the wwan0 interface does not get assigned and IP and dhclient does not get a response either.
How should I configure it? Ideally I want to set it into /etc/network/interfaces so it will connect at boot.
I am on Ubuntu 14.04 Server.
Here is the output from dmesg:
```auto
[2.489035] usb 1-5: new high-speed USB device number 4 using xhci_hcd
[2.516771] usb 1-5: config 1 has an invalid interface number: 8 but max is 5
[2.523818] usb 1-5: config 1 has an invalid interface number: 10 but max is 5
[2.523819] usb 1-5: config 1 has an invalid interface number: 11 but max is 5
[2.523826] usb 1-5: config 1 has no interface number 1
[2.523829] usb 1-5: config 1 has no interface number 4
[2.523833] usb 1-5: config 1 has no interface number 5
[2.576398] usb 1-5: New USB device found, idVendor=1199, idProduct=68c0
[2.582571] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[2.588829] usb 1-5: Product: MC7304
[2.588831] usb 1-5: Manufacturer: Sierra Wireless, Incorporated
[18.452576] usbcore: registered new interface driver usbserial
[18.452586] usbcore: registered new interface driver usbserial_generic
[18.452592] usbserial: USB Serial support registered for generic
[18.505217] usbcore: registered new interface driver cdc_wdm
[18.505386] usbcore: registered new interface driver qcserial
[18.505405] usbserial: USB Serial support registered for Qualcomm USB modem
[18.512255] qcserial 1-5:1.0: Qualcomm USB modem converter detected
[18.512337] usb 1-5: Qualcomm USB modem converter now attached to ttyUSB0
[18.520279] qcserial 1-5:1.2: Qualcomm USB modem converter detected
[18.520336] usb 1-5: Qualcomm USB modem converter now attached to ttyUSB1
[18.525646] qcserial 1-5:1.3: Qualcomm USB modem converter detected
[18.525710] usb 1-5: Qualcomm USB modem converter now attached to ttyUSB2
[18.557315] qmi_wwan 1-5:1.8: cdc-wdm1: USB WDM device
[18.557904] qmi_wwan 1-5:1.8 wwan0: register 'qmi_wwan' at usb-0000:00:14.0-5, WWAN/QMI device, 32:d8:ac:1b:14:11
[18.560861] qmi_wwan 1-5:1.10: cdc-wdm2: USB WDM device
[18.561186] qmi_wwan 1-5:1.10 wwan1: register 'qmi_wwan' at usb-0000:00:14.0-5, WWAN/QMI device, 32:d8:ac:1b:14:11
[18.562097] qmi_wwan 1-5:1.11: cdc-wdm3: USB WDM device
[18.562195] qmi_wwan 1-5:1.11 wwan2: register 'qmi_wwan' at usb-0000:00:14.0-5, WWAN/QMI device, 32:d8:ac:1b:14:11
[18.562222] usbcore: registered new interface driver qmi_wwan
Here is output from qmicli:
```auto
[/dev/cdc-wdm1] Successfully got system info:
        GSM service:
                Status: 'none'
                True Status: 'none'
                Preferred data path: 'no'
        WCDMA service:
                Status: 'available'
                True Status: 'available'
                Domain: 'cs-ps'
                Service capability: 'cs-ps'
                Roaming status: 'off'
                Forbidden: 'no'
                Location Area Code: '32200'
                Cell ID: '196610508'
                MCC: '505'
                MNC: '02'
                HS call status: 'hsdpa-hsupa-unsupported'
                HS service: 'dc-hsdpa-plus-hsupa-supported'
                Primary scrambling code: '44'
                Cell broadcast support: 'off'
                Call barring status (CS): 'all-calls'
                Call barring status (PS): 'all-calls'
                Cipher Domain: 'none'
        LTE service:
                Status: 'none'
                True Status: 'none'
        SIM reject info: 'vailable'
Here are the commands I tried to use to connect:
```auto
leith@server:~$ sudo qmi-network /dev/cdc-wdm1 start
Loading previous state...
/usr/bin/qmi-network: 72: /usr/bin/qmi-network: source: not found
Starting network with 'qmicli -d /dev/cdc-wdm1 --wds-start-network= --client-no-release-cid'...
Saving state... (CID: 12)
Saving state... (PDH: 1205786472)
Network started successfully
leith@server:~$ sudo qmi-network /dev/cdc-wdm1 status
Getting status with 'qmicli -d /dev/cdc-wdm1 --wds-get-packet-service-status '...
Status: connected
leith@server:~$ sudo ifconfig wwan0 up
leith@server:~$ sudo dhclient -v wwan0
Internet Systems Consortium DHCP Client 4.2.4
Copyright 2004-2012 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wwan0/32:d8:ac:1b:14:11
Sending on LPF/wwan0/32:d8:ac:1b:14:11
Sending on Socket/fallback
DHCPDISCOVER on wwan0 to 255.255.255.255 port 67 interval 3 (xid=0x5f89d54a)
DHCPDISCOVER on wwan0 to 255.255.255.255 port 67 interval 5 (xid=0x5f89d54a)
DHCPDISCOVER on wwan0 to 255.255.255.255 port 67 interval 13 (xid=0x5f89d54a)
DHCPDISCOVER on wwan0 to 255.255.255.255 port 67 interval 11 (xid=0x5f89d54a)
^Cleith@server:~$ sudo ifconfig wwan0 down
leith@server:~$ sudo qmi-network /dev/cdc-wdm1 stop
Network already stopped
Clearing state...
leith@server:~$
_[View the full topic](https://forum.sierrawireless.com/t/how-to-connect-via-qmi-wwan-on-ubuntu/7365)._
