# HL7810, MQTT Certs and ERROR code 907
**URL:** <https://forum.sierrawireless.com/t/hl7810-mqtt-certs-and-error-code-907/30941>\
**Category:** Legacy HL Series\
**Tags:** debug\
**Created:** [October 29, 2023, 2:52am UTC](https://forum.sierrawireless.com/t/hl7810-mqtt-certs-and-error-code-907/30941 "2023-10-29T02:52:34Z")\
**Showing post:** 20
**Post date:** [October 30, 2023, 1:48pm UTC](https://forum.sierrawireless.com/t/hl7810-mqtt-certs-and-error-code-907/30941/20 "2023-10-30T13:48:12Z")
I think need to first figure out if your cert problem or other problem
Test here shows that custom server works with the custom cert
> [@Tls hl7800 4.6.9.4](https://forum.sierrawireless.com/t/tls-hl7800-4-6-9-4/29861/3):
> Hello @jerdung, I just removed the OK response (I merge 2 separate terminal to display both side of the serial). There is no issue for that. I tried a dummy client certificate and key but didn’t achieve anything. We don’t use the client certificate for identification on the server side but maybe I made a mistake during this operation. We have to register one ? I based my test on a previous response on this forum where only the CA Root was stored. Can you help me in the step to generate/ret…
_[View the full topic](https://forum.sierrawireless.com/t/hl7810-mqtt-certs-and-error-code-907/30941)._
