Help with EM7565 Firmware and PRI File Update on Linux
A quick update on the situation.
Initially, I was connecting the modules via a USB hub. After some troubleshooting, I decided to connect the module directly to a PC USB port. This allowed me to move one step further, but the process still hasn’t completed.
The download seems to proceed without issues, as shown by the following log:
sudo ./fw-download-toolhostx86_64 -l pcie_mbim_1.log -f /home/rvl/EM7565/011402/ -m 4 -d /dev/ttyUSB0 -p /dev/cdc-wdm0 -t 1 -c MBIM -w SWI9X50C_01.14.02.00.cwe -n SWI9X50C_01.14.02.00_GENERIC_002.035_003.nvu
Application version: 1.0.2405.0
INFO: QDL Port: /dev/ttyUSB0
INFO: Device Path: /dev/cdc-wdm0
INFO: Device Port: 0-0
INFO: FW Path: /home/rvl/EM7565/011402/
Target image Info:
Carrier    :GENERIC
FW Version :01.14.02.00
Model ID   :SWI9X50C
Package ID :003
PRI Version:002.035
SKU        :9999999
Modem is already in QDL mode. Continuing FW download.
Waiting for modem to come up in BOOT and HOLD mode ...
BOOT and HOLD Mode. Downloading firmware ...
Downloading: /home/rvl/EM7565/011402//SWI9X50C_01.14.02.00_GENERIC_002.035_003.nvu
Downloading: /home/rvl/EM7565/011402//SWI9X50C_01.14.02.00.cwe
All image data was downloaded successfully.
Device is about to reset ...
Waiting for modem to come up in ONLINE mode ...
Modem is now in ONLINE mode ...
The process now stops at the line “Modem is now in ONLINE mode…”. Even though the data download appears successful, the new firmware does not show up in the list of installed images:
at!image?
TYPE SLOT STATUS LRU FAILURES UNIQUE_ID   BUILD_ID
FW   1    GOOD   2   0 0      ?_?         01.08.04.00_?
FW   2    GOOD   3   0 0      ?_?         01.07.02.00_?
FW   3    GOOD   1   0 0      ?_?         01.09.04.00_?
FW   4    EMPTY  0   0 0
Max FW images: 4
Active FW image is at slot 255
PRI  FF   GOOD   0   0 0      002.008_004 01.07.02.00_ATT
PRI  FF   GOOD   0   0 0      002.015_000 01.09.04.00_DOCOMO
PRI  FF   GOOD   0   0 0      002.035_003 01.14.02.00_GENERIC
PRI  FF   GOOD   0   0 0      002.001_000 01.08.04.00_SIERRA
PRI  FF   GOOD   0   0 0      002.017_000 01.09.04.00_SOFTBANK
PRI  FF   GOOD   0   0 0      000.001_001 01.08.04.00_SPRINT
PRI  FF   GOOD   0   0 0      001.000_000 01.07.02.00_TELUS
PRI  FF   GOOD   0   0 0      002.015_001 01.08.04.00_VERIZON
Max PRI images: 50
But ati command shows the firmware 01.14.02 is used
ati
Model: EM7565
Revision: SWI9X50C_01.14.02.00 2e210b jenkins 2020/08/19 14:18:39
IMEI: ******************
IMEI SV: 12
FSN: ******************
+GCAP: +CGSM
at!priid?
PRI Part Number: 9907344
Revision: 002.003
Customer: Generic-M2M
Carrier PRI: 9999999_9907259_SWI9X50C_01.14.02.00_00_GENERIC_002.035_003
at!impref?
!IMPREF:
 preferred fw version:    01.14.02.00
 preferred carrier name:  GENERIC
 preferred config name:   GENERIC_002.035_003
 preferred subpri index:  000
 current fw version:      01.14.02.00
 current carrier name:    GENERIC
 current config name:     GENERIC_002.035_003
 current subpri index:    000
