# GSM network problem
**URL:** <https://forum.sierrawireless.com/t/gsm-network-problem/4906>\
**Category:** Open AT\
**Created:** [February 21, 2011, 9:07am UTC](https://forum.sierrawireless.com/t/gsm-network-problem/4906 "2011-02-21T09:07:37Z")\
**Showing post:** 6
**Author:** ![awneil](https://avatars.discourse-cdn.com/v4/letter/a/49beb7/32.png) [@awneil](https://forum.sierrawireless.com/u/awneil)\
**Post date:** [February 21, 2011, 1:13pm UTC](https://forum.sierrawireless.com/t/gsm-network-problem/4906/6 "2011-02-21T13:13:50Z")
> [@zafer](#):
> -Our customer says that modem is still blinking when it happens.
That should indicate that the modem is registered (or, at least, that it thinks it is registered);
if it were in the WIND: 7 “stuck” state, the LED would be steady.
> Our logs says AT+CREG? responses “stat” as “1”(registered home network).
Indeed - the modem thinks that it is registered…
> operator message says “The number you’ve called can not be reached at the moment…”
… but the network thinks that it is not registered!
> -Modem can not receive SMS in this state.
If you enable delivery receipts, does the network think that the SMS has been delivered?
> -It is not releated with GPRS because it always happens after GPRS disconnection
I mean, can you reconnect to GPRS once this has happened?
If so, does reconnecting to GPRS also restore the GSM registration?
_[View the full topic](https://forum.sierrawireless.com/t/gsm-network-problem/4906)._
