i used the code which gave in the sample code only,
based on your suggestion i tried as follows still i face the same issue
the adl_flhWrite() call inside of gps_flashWrite() see next code for gps_flashWrite()
if ( TRUE == gps_flashInit() )
     lengthRead = gps_flashWrite(GPS_CONTEXT_FLASH_ID, (u8 *) &gpsAtLocalContext, sizeof(gps_atContext_t));
      if(lengthRead == sizeof(gps_atContext_t) )
        if(TRUE == gps_flashExist(GPS_CONTEXT_FLASH_ID, sizeof(gps_atContext_t)))
            lengthRead = gps_flashRead(GPS_CONTEXT_FLASH_ID, (u8 *) &gpsAtLocalContext, sizeof(gps_atContext_t));
            // Is context is valid?
            if ( lengthRead == sizeof(gps_atContext_t) )
                // Saved context found, copy to current context
                wm_memcpy(&gpsAtContext,&gpsAtLocalContext, sizeof(gps_atContext_t));
                // GPS Plug-In library state configuration
                if ( gpsAtContext.eGpsState != GPS_UNINITIALIZED )
                    // Data for Init message
                    l_t_eventMessageData.eAtEventMessageType = GPS_AT_EVENT_MESSAGE_INIT_CMD_SUB;
                    l_t_eventMessageData.eAtEventPort = gpsAtContext.eAtPort;
                    // Case of Automatic Init or Start
                    // Send the message for library initialization
                    retStatus =  adl_msgSend (   g_e_atCtxID, GPS_AT_MESSAGE_ID, sizeof(gps_atEventMessageData_t), (void *)&l_t_eventMessageData);
                    if (retStatus < 0)
                        // Error during message transmission
                        TRACE(( GPS_AT_MSG_TRACE_LEVEL,"[gps_atCmdSubscribe] Message send failed [%d]", retStatus));
                        snprintf( RspStr, sizeof(RspStr), GPS_AT_ERROR_FORMAT_STRING, GPS_AT_ERROR_STR, GPS_AT_ERR_SCHED_TASK);
                        adl_atSendResponsePort ( ADL_AT_UNS, gpsAtContext.eAtPort, RspStr );
                        return ERROR;
            } // if( lengthRead == sizeof(gps_atContext_t))
            else
                TRACE(( GPS_AT_MSG_TRACE_LEVEL ,"[gps_atCmdSubscribe] Flash size error [%d]", lengthRead));
                snprintf( RspStr, sizeof(RspStr), GPS_AT_ERROR_FORMAT_STRING, GPS_AT_ERROR_STR, GPS_AT_ERR_FLASH_DATA_ACCESS);
                return ERROR;
        } // (TRUE == gps_flashExist(..
        else
            TRACE(( GPS_AT_MSG_TRACE_LEVEL ,"[gps_atCmdSubscribe] Flash object not loaded"));
        else
    else //  if(TRUE == gps_flashInit())
        TRACE(( GPS_AT_MSG_TRACE_LEVEL ,"[gps_atCmdSubscribe] Flash access error"));
        return ERROR;
the gps_flashWrite()as defined as follows
u32 gps_flashWrite(u16 flashID, u8 *nvData, u32 length)
	s32 l_s32_status;
	// Make sure that the data object exists and is the correct size.  Otherwise, do cold start
	/*l_s32_status = adl_flhExist((ascii*)GPSatContext_flashHandle, flashID);
	if ( l_s32_status < 0)
		TRACE((GPS_AT_FLASH_TRACE_LEVEL, "[gps_flashWrite] Flash error (%d): Flash ID %d, length: %d", l_s32_status, flashID, length));
		length = 0;
        return length;
	else if(l_s32_status == OK)
		TRACE((GPS_AT_FLASH_TRACE_LEVEL, "[gps_flashWrite] Flash ID %d Object does not exist, length (%d) ", flashID, length));
	else if(l_s32_status != length)
		TRACE((GPS_AT_FLASH_TRACE_LEVEL, "[gps_flashWrite] Flash Object ID %d: length (%d) not equal to required length (%d)", flashID, l_s32_status, length));
	if (adl_flhWrite((ascii*)GPSatContext_flashHandle, (u16)flashID, (u16)length, nvData) == OK)
#ifdef _GPS_AT_FLASH_TRACE_LEVEL_DEBUG_
    	TRACE((GPS_AT_FLASH_TRACE_LEVEL, "[gps_flashWrite]: Run Flash Data (length %d), Remaining: %d",length,adl_flhGetFreeMem()));
#endif // _GPS_AT_FLASH_TRACE_LEVEL_DEBUG_
    else
    	TRACE((GPS_AT_FLASH_TRACE_LEVEL, "[gps_flashWrite] Flash write error: ID %d, length: %d", flashID, length));
	return length;
can you explain how solve this flash error
