Get "Current WAN Time in Use" via API
is it possible to “Synchronize System” and get the “Current WAN Time in Use” value (AV -> Monitor -> Systems -> [NAME] -> Configuration -> Status -> Cellular -> Monitor) via API?
In addition: I created an example project of how to use AirVantage API with PowerShell 5 on GitHub (doc.airvantage.net/av/howto/cloud/api_examples/).
Thanks & br,
Martin
Hi Martin,
Synchronize system will read a list of hard-coded data from the device and the “Current WAN Time in Use” data is not in this list.
To read this data, you have to:
About your Power Shell script, it will be a pleasure to add it in the library page.
Robert
Hi Robert,
thanks a lot - I’ll give it a try…
Martin
#4
Hi Robert,
Update:
My goal is to compare “Current WAN Time in Use” and “Device Uptime” - with the provided information I was able to do that - Many thanks. :smiley:
I also updated the sample script on GitHub.
Br,
Martin
#5
Hi Martin,
your example has been added in the API & examples page.
Robert
