# FX30 Firmware Refresh
**URL:** <https://forum.sierrawireless.com/t/fx30-firmware-refresh/9204>\
**Category:** FX30\
**Created:** [May 21, 2017, 7:40pm UTC](https://forum.sierrawireless.com/t/fx30-firmware-refresh/9204 "2017-05-21T19:40:17Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![HeinSierra](https://avatars.discourse-cdn.com/v4/letter/h/ebca7d/32.png) [@HeinSierra](https://forum.sierrawireless.com/u/HeinSierra)\
**Post date:** [May 21, 2017, 7:40pm UTC](https://forum.sierrawireless.com/t/fx30-firmware-refresh/9204/1 "2017-05-21T19:40:17Z")
</div>
Hi all,
while I am working on an app for the FX30, it seems that the firmware of the FX30 crashed. The only interface I can see is the DM port (COM xx). I currently have no Linux system, only Windows 7 with Docker and Dev Studio (v5.1) is available. I have no access via ssh.
Sometimes the FX30 seems to reboot and I can see the normal interfaces for a very short time.
This is the second FX30 with the same behavior. I do not know is there a problem with my app or is there still a fault with the FX30 and / or the firmware. I want to refresh the FW, but I don’t know how can I do this under Windows 7? Is there another way to set the legato in the factory setting or return to the normal function?
Best regards
Hein
PS: Both FX30 are new with FW 13.1.2.004
**Author:** ![mlw](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.sierrawireless.com/mlw/32/3706_2.png) [@mlw](https://forum.sierrawireless.com/u/mlw)\
**Post date:** [May 24, 2017, 6:51am UTC](https://forum.sierrawireless.com/t/fx30-firmware-refresh/9204/2 "2017-05-24T06:51:17Z")
</div>
For the record here couple of things to try.
- Check the PID out for the states it gets into, the FX30 should normally be 68C0, if it is something else then something is wrong.
- The unit only enumerates a single com port when there is a probem with the firmware and it falls back to the Qualcomm boot loader.
- To try and create a one click updater for windows which is not on the source take the WP8 one click updater, open it with pkzip/izarc and replace the WP8 CWE file with the CWE file for the FX30 and you should be able to update the unit from windows now. Note this is obviously a hack but the tools are all the same.
