# Failure to configure I2C subscription
**URL:** <https://forum.sierrawireless.com/t/failure-to-configure-i2c-subscription/8027>\
**Category:** Open AT\
**Created:** [June 30, 2015, 8:59pm UTC](https://forum.sierrawireless.com/t/failure-to-configure-i2c-subscription/8027 "2015-06-30T20:59:41Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![mattmc318](https://avatars.discourse-cdn.com/v4/letter/m/f4b2a3/32.png) [@mattmc318](https://forum.sierrawireless.com/u/mattmc318)\
**Post date:** [June 30, 2015, 8:59pm UTC](https://forum.sierrawireless.com/t/failure-to-configure-i2c-subscription/8027/1 "2015-06-30T20:59:41Z")
</div>
I’m trying to set up I2C on my device (SL8080T), but I’m having issues. I’ve followed the sample code in the ADL user guide (§3.13.18), and came up with the following test program, intended to subscribe to the I2C service, and write a buffer to it every second:
```auto
#include "adl_global.h"
#include "adl_bus.h"
#include "generated.h"
// Temporary global values
u8 buffer[] = {0xAA, 0x0F, 0x0F, 0xAA};
adl_busAccess_t AccessConfig = {0,0};
s32 MyI2CHandle;
adl_busI2CSettings_t MyI2CConfig = {
	0x20, // Chip address is 0x20
	ADL_BUS_I2C_CLK_STD, // Chip uses the I2C standard clock speed
	ADL_BUS_I2C_ADDR_7_BITS, // 7 bits address length
	ADL_BUS_I2C_MASTER_MODE // Master mode
// Timer handler
void write_test() {
	s32 ret = adl_busWrite( MyI2CHandle, &AccessConfig, sizeof(u8) * 4, buffer );
	switch( ret ) {
		default:
		case OK:
			TRACE(( 1, "OK" ));
			break;
		case ERROR:
			TRACE(( 1, "ERROR" ));
			break;
		case ADL_RET_ERR_UNKNOWN_HDL:
			TRACE(( 1, "ADL_RET_ERR_UNKNOWN_HDL" ));
			break;
		case ADL_RET_ERR_PARAM:
			TRACE(( 1, "ADL_RET_ERR_PARAM" ));
			break;
		case ADL_RET_ERR_SERVICE_LOCKED:
			TRACE(( 1, "ADL_RET_ERR_SERVICE_LOCKED" ));
			break;
// Entry point for ADL user application
void main_task()
	TRACE(( 1, "main_task" ));
	MyI2CHandle = adl_busSubscribe( ADL_BUS_ID_I2C, 1, &MyI2CConfig );
	switch( MyI2CHandle ) {
			break;
		case ADL_RET_ERR_ALREADY_SUBSCRIBED:
			TRACE(( 1, "ADL_RET_ERR_ALREADY_SUBSCRIBED" ));
			break;
		case ADL_RET_ERR_BAD_HDL:
			TRACE(( 1, "ADL_RET_ERR_BAD_HDL" ));
			break;
		case ADL_RET_ERR_NOT_SUPPORTED:
			TRACE(( 1, "ADL_RET_ERR_NOT_SUPPORTED" ));
			break;
			break;
		default:
			TRACE(( 1, "MyI2CHandle == 0x%.8x", MyI2CHandle ));
			adl_tmrSubscribe( TRUE, 10, ADL_TMR_TYPE_100MS, (adl_tmrHandler_t) write_test );
			break;
The adl\_busSubscribe function is successful, but each call to adl\_busWrite returns the value ADL\_RET\_ERR\_PARAM. I can’t seem to figure out, however, where the issue lies. Is there something I’m doing wrong?
Here’s some additional diagnostic information, including the device number and firmware version:
```auto
ati9
"DWL"," B04.05.18.00.SL8RDBT R2509 CNSHZ-ED-XP0029 2015/04/23 15:10:23","","Sierra Wireless",0,"","00000000","00000000"
"FW","FW_753_1_A1_4.SL808FAx","B7.53.1.A1.201411071126.SL8080T","Sierra Wireless",1943676,"110714 11:26","4380cd1b","10002020"
"MODEM 3G+","Revision: B04.05.05.00.SL8RDAP R2339 CNSHZ-ED-XP0029 2014/11/07 15:28:21"
"OAT","1.0.0.20150630145156","MyApplication","Minium LLC",215176,"063015 14:51","5962f825","10700000"
 -"Developer Studio","3.4.0.201506101227"
 -"Open AT Application Framework package","2.53.1.A1.201411071700"
 -"Open AT OS Package","6.53.1.A1.201410271301"
 -"Firmware Package","7.53.1.A1.201411071126"
 -"ExtendedATApplication Library Package","2.1.0.A1.201411071534"
 -"eCall Library Package","1.3.3.201411071021"
 -"Local Trace Session Library Package","1.1.0.201410231018"
 -"Location Library Package","1.4.6.201310160912"
 -"Security Library Package","2.2.0.201306261000"
 -"Internet Library Package","5.57.1.A1.201410101134"
"ROM","8400000"
"RAM","4000000"
"OATRAM","b00000"
"DWLNAME","SL808xA"
**Author:** ![Rex\_alex](https://avatars.discourse-cdn.com/v4/letter/r/73ab20/32.png) [@Rex\_alex](https://forum.sierrawireless.com/u/Rex_alex)\
**Post date:** [July 6, 2015, 5:40am UTC](https://forum.sierrawireless.com/t/failure-to-configure-i2c-subscription/8027/2 "2015-07-06T05:40:48Z")
</div>
You can refer the SDK sample “External\_storage\_I2C”.
Alex
**Post date:** [July 7, 2015, 9:21pm UTC](https://forum.sierrawireless.com/t/failure-to-configure-i2c-subscription/8027/3 "2015-07-07T21:21:42Z")
</div>
It turns out that I had just used the wrong chip address. Shifting the byte one position to the right got rid of the R/W bit, which I had needed for a different application library. OpenAT only requires the 7 bits before the LSB, and appends the R/W bit on its own.
Thanks for your help.
**Author:** ![awneil](https://avatars.discourse-cdn.com/v4/letter/a/49beb7/32.png) [@awneil](https://forum.sierrawireless.com/u/awneil)\
**Post date:** [July 7, 2015, 10:06pm UTC](https://forum.sierrawireless.com/t/failure-to-configure-i2c-subscription/8027/4 "2015-07-07T22:06:39Z")
</div>
> [@mattmc318](#):
Yes - I find that is a common frustration with I2C libraries ❗
**Post date:** [July 8, 2015, 10:23am UTC](https://forum.sierrawireless.com/t/failure-to-configure-i2c-subscription/8027/5 "2015-07-08T10:23:06Z")
</div>
Someone else found the same: [https://forum.sierrawireless.com/t/i2c-works-devkit/8036/2](https://forum.sierrawireless.com/t/i2c-works-devkit/8036/2)
