# Em7565 no 3xCA on band 41
**URL:** <https://forum.sierrawireless.com/t/em7565-no-3xca-on-band-41/9754>\
**Category:** MC/EM Series\
**Created:** [January 21, 2018, 8:38pm UTC](https://forum.sierrawireless.com/t/em7565-no-3xca-on-band-41/9754 "2018-01-21T20:38:54Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![westrem](https://avatars.discourse-cdn.com/v4/letter/w/f9ae1b/32.png) [@westrem](https://forum.sierrawireless.com/u/westrem)\
**Post date:** [January 21, 2018, 8:38pm UTC](https://forum.sierrawireless.com/t/em7565-no-3xca-on-band-41/9754/1 "2018-01-21T20:38:54Z")
</div>
I’m using the em7565 with sprint in a 3xCA area confirmed with a note 8 phone. I am only getting 2xCA. I should be getting 3xCA with band 41. (41+41+41)
At!gstatus?
!GSTATUS:
Current Time: 820 Temperature: 36
Reset Counter: 1 Mode: ONLINE
LTE band: B41 LTE bw: 20 MHz
LTE Rx chan: 41374 LTE Tx chan: 41374
LTE SSC1 state:ACTIVE LTE SSC1 band: B41
LTE SSC1 bw : Unknown LTE SSC1 chan: 41176
LTE SSC2 state:NOT ASSIGNED
LTE SSC3 state:NOT ASSIGNED
LTE SSC4 state:NOT ASSIGNED
RRC state: RRC Connected
IMS reg state: No Srv
PCC RxM RSSI: -64 PCC RxM RSRP: -92
PCC RxD RSSI: -67 PCC RxD RSRP: -95
SCC1 RxM RSSI: -63 SCC1 RxM RSRP: -93
SCC1 RxD RSSI: -65 SCC1 RxD RSRP: -95
Tx Power: 6 TAC: 2639 (9785)
RSRQ (dB): -9.2 Cell ID: 04d4be43 (81051203)
SINR (dB): 12.8
**Author:** ![unknown](https://avatars.discourse-cdn.com/v4/letter/u/4bbf92/32.png) [@unknown](https://forum.sierrawireless.com/u/unknown)\
**Post date:** [January 26, 2018, 3:34pm UTC](https://forum.sierrawireless.com/t/em7565-no-3xca-on-band-41/9754/2 "2018-01-26T15:34:15Z")
</div>
Are you using a Note 8 with a Snapdragon SoC? Only the Snapdragon version shares the same modem. You should ensure the Snapdragon X16 (Modem) supports this band combination.
**Post date:** [January 26, 2018, 6:36pm UTC](https://forum.sierrawireless.com/t/em7565-no-3xca-on-band-41/9754/3 "2018-01-26T18:36:36Z")
</div>
My sprint note 8 uses the Snapdragon 835 ( which holds the X16 modem) and it does support 41+41+41
**Post date:** [January 26, 2018, 7:00pm UTC](https://forum.sierrawireless.com/t/em7565-no-3xca-on-band-41/9754/4 "2018-01-26T19:00:52Z")
</div>
I locked band 41 and now it works.
At!gstatus?
!GSTATUS:
Current Time: 145 Temperature: 32
Reset Counter: 6 Mode: ONLINE
LTE SSC2 state:ACTIVE LTE SSC2 band: B41
LTE SSC2 bw : Unknown LTE SSC2 chan: 40978
PCC RxM RSSI: -66 PCC RxM RSRP: -94
PCC RxD RSSI: -69 PCC RxD RSRP: -97
SCC1 RxM RSSI: -66 SCC1 RxM RSRP: -94
SCC1 RxD RSSI: -69 SCC1 RxD RSRP: -97
SCC2 RxM RSSI: -67 SCC2 RxM RSRP: -94
SCC2 RxD RSSI: -71 SCC2 RxD RSRP: -98
Tx Power: 14 TAC: 2639 (9785)
RSRQ (dB): -13.7 Cell ID: 04d4be43 (81051203)
SINR (dB): 10.0
**Author:** ![KOSH](https://avatars.discourse-cdn.com/v4/letter/k/77aa72/32.png) [@KOSH](https://forum.sierrawireless.com/u/KOSH)\
**Post date:** [January 31, 2018, 9:14pm UTC](https://forum.sierrawireless.com/t/em7565-no-3xca-on-band-41/9754/5 "2018-01-31T21:14:57Z")
</div>
at!gstatus?
!GSTATUS:
Current Time: 50425 Temperature: 23
LTE band: B1 LTE bw: 10 MHz
LTE Rx chan: 397 LTE Tx chan: 18397
LTE SSC1 state:ACTIVE LTE SSC1 band: B3
LTE SSC1 bw : Unknown LTE SSC1 chan: 1875
LTE SSC2 state:ACTIVE LTE SSC2 band: B7
LTE SSC2 bw : Unknown LTE SSC2 chan: 3350
PCC RxM RSSI: -43 PCC RxM RSRP: -66
PCC RxD RSSI: -44 PCC RxD RSRP: -67
SCC1 RxM RSSI: -77 SCC1 RxM RSRP: -108
SCC1 RxD RSSI: -30 SCC1 RxD RSRP: -61
SCC2 RxM RSSI: -36 SCC2 RxM RSRP: -68
SCC2 RxD RSSI: -40 SCC2 RxD RSRP: -72
Tx Power: – TAC: xxxx (xxxxx)
RSRQ (dB): -7.9 Cell ID: xxxxxxxx (xxxxxxxx)
SINR (dB): 25.4
I am also from Ausrtria with B1+B3+B7
Modulation not always work only for 1 Band.
In the evening Primary serving cell jump to other in my case B3 and it work
 ![](http://www.speedtest.net/result/6985003862.png)
How we can select Primary serving cell by own or lock to it .Is this possible ?
I set Modulation Report to 1 at+MR=1 but nothing happen I can see no status. It is in +GCAP not integrate .
I see in Reference book something about RRC (Radio Resource Control)but I can not found it in Modem
!CUSTOM commands
“LTEREJDELAY”—Set delay before LTE attach requests are sent after TAU or
service request rejection.
• 0–255 = Delay in 10 msec units. (e.g. 10=100 msec)
• Actual range is 0–2.55 sec
• Delay is cancelled if RRC connection is released early.
• Suggested value (if delay is being enabled) is 50 (500 msec). Adjust the
value as necessary based on testing.
