When installing the the Gobi driver (GobiSerial/GobiNet), it is advised in Application developer guide that ‘ModemManager’ should be removed as it interferes SDK operations.
Does Linux default NetworkManager also has any impact on SDK operation for WP/MC series modems?
or NetworkManager and SDK can run together without any issue?
Typically modemmanager will send config commands and request information so probably will not impact the unit when running QMI, however, if it starts calls, data session’s, etc then obviously things will start happening which will confuse you as it will be invisible to QMI operation.
