# Console.log() output not in logread unless costly logging is enabled
**URL:** <https://forum.sierrawireless.com/t/console-log-output-not-in-logread-unless-costly-logging-is-enabled/29889>\
**Category:** Octave\
**Created:** [May 31, 2023, 12:27am UTC](https://forum.sierrawireless.com/t/console-log-output-not-in-logread-unless-costly-logging-is-enabled/29889 "2023-05-31T00:27:57Z")\
**Showing post:** 3
**Author:** ![njoyeux](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.sierrawireless.com/njoyeux/32/6714_2.png) [@njoyeux](https://forum.sierrawireless.com/u/njoyeux)\
**Post date:** [May 31, 2023, 7:31am UTC](https://forum.sierrawireless.com/t/console-log-output-not-in-logread-unless-costly-logging-is-enabled/29889/3 "2023-05-31T07:31:22Z")
Hi @dpinc
While I don’t reproduce the behavior you mention (see my answer in [Edge Action logs no longer available in syslog](https://forum.sierrawireless.com/t/edge-action-logs-no-longer-available-in-syslog/29809), I can see the console logs without enabling logs),
you can suppress the push of diagnostic logs by removing the `logs` observation after having enabled the logs.
 ![image](https://us1.discourse-cdn.com/flex025/uploads/sierrawireless/original/2X/e/ed9f7af90193723a3e8413ad8a398450a5917a54.png)
Nicolas
_[View the full topic](https://forum.sierrawireless.com/t/console-log-output-not-in-logread-unless-costly-logging-is-enabled/29889)._
