Command Line Build
Is there a simple way to do a command line build? ( using 1.2 )
In online help, please refer to Developer Studio User Guide > Build System > Advanced topics > Building projects in headless mode
Is there any way to stop the java window from popping up after a command line triggered build failure? It’s interfering with our CI.
Under Windows + using m2mstudio.exe and -console option, it’s not possible.
But instead of using the m2mstudio.exe launcher, you can invoke the JVM (java.exe) with the correct jar file: output will be printed in the console you used to invoke the command (and not in a second popup window).
cf wiki.eclipse.org/Starting_Eclips … x_Launcher
(Note that in this case you should not need the -console option anymore)
