I’m working with a Sierra Wireless WP7702. When I built an image using the generic SPK, the Verizon PRI appeared in the output of the AT!IMPREF commands, but I couldn’t successfully switch to it.
I rebuilt the image using the Verizon SPK and it came up fine, but fwupdate is buggy and the device needed a hard power cycle t0o finish the update. Not ideal for remote, unmanned devices.
Is it possible to select and use the Verizon PRI while running the generic SPK, or does the Verizon PRI require the matching Verizon firmware package? If it is supported, are there prerequisites or additional steps beyond selecting the preferred firmware/carrier configuration with AT!IMPREF?
what is the output of AT!image? and AT!impref? right now?
BTW, you can first download the official VZW spk, and then the module should be able to switch to VZW.
After that you can download your custom yocto or legato image.
right but can you switch between GENERIC and VERIZON without using fwupdate to push an sdk file?
AT!impref? was showing a Verizon PRI was available, but would not switch to it when i just used the GENERIC spk in my output image. It took me recreating the image with the VERIZON SPK to switch the PRI.
