Calling cm at boot time
I wanted to use cm info fsn, or cm data info in init.d files but I get the following error:
root: run_getty.sh: No UART mapped to CONSOLE
Is there any solution to solve this problem?
Alain
Hi Alain,
You cannot issue Legato commands prior to Legato starting up at S44.
BR,
Chris
Hello Chris,
Ok but I’m starting at S90, through rc5.d so I’m supposed to execute cm after legato starting up no?
Here is the syslog. The last lines is where I execute cm:
Alain
#4
Any idea please?
Alain
#5
Hi Alain,
Can you try S90 in rcS.d? Are you certain your changes are being called properly? I don’t think rc5.d is being called.
BR,
Chris
#6
Hi Chris,
I verified how our yocto image is built:
install -d ${D}${sysconfdir}/init.d
install -d ${D}${sysconfdir}/rcS.d
install -d ${D}${sysconfdir}/rc1.d
install -d ${D}${sysconfdir}/rc2.d
install -d ${D}${sysconfdir}/rc3.d
install -d ${D}${sysconfdir}/rc4.d
install -d ${D}${sysconfdir}/rc5.d
install -m 0544 ${WORKDIR}/initscript.sh        			${D}${sysconfdir}/init.d/blackbox
ln -sf ../init.d/blackbox        ${D}${sysconfdir}/rcS.d/S90blackbox
ln -sf ../init.d/blackbox        ${D}${sysconfdir}/rc1.d/K90run-script
ln -sf ../init.d/blackbox        ${D}${sysconfdir}/rc2.d/K90run-script
ln -sf ../init.d/blackbox        ${D}${sysconfdir}/rc3.d/K90run-script
ln -sf ../init.d/blackbox        ${D}${sysconfdir}/rc4.d/K90run-script
ln -sf ../init.d/blackbox        ${D}${sysconfdir}/rc5.d/S90run-script
Do you agree with that?
And according to the log I provided in a previous post, cm command is performed after Legato started up.
Alain
