# bc127 auto play music
**URL:** <https://forum.sierrawireless.com/t/bc127-auto-play-music/9216>\
**Category:** WiFi and Bluetooth Modules\
**Created:** [May 24, 2017, 2:55pm UTC](https://forum.sierrawireless.com/t/bc127-auto-play-music/9216 "2017-05-24T14:55:25Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![fred128](https://avatars.discourse-cdn.com/v4/letter/f/ce7236/32.png) [@fred128](https://forum.sierrawireless.com/u/fred128)\
**Post date:** [May 24, 2017, 2:55pm UTC](https://forum.sierrawireless.com/t/bc127-auto-play-music/9216/1 "2017-05-24T14:55:25Z")
</div>
I use bc127 to stream music as a source to a bluetooth speaker.
It works great but i would like the a2dp stream to start automaticaly when connected to speaker. I don’t want to have to use music link\_id play command if it’s possible?
Or at least I think it’s possible to sent the command remotely from the speaker with hfp I think?
But if there is an automatic start stream parameter it would be great.
thank you
**Post date:** [May 24, 2017, 11:02pm UTC](https://forum.sierrawireless.com/t/bc127-auto-play-music/9216/2 "2017-05-24T23:02:37Z")
</div>
I read documentation and i think i must use the MUSIC command. And to remotely start streaming i have to use gpio2 from a bc127 receiver.
I have a bluetooth speaker with play/pause button but it seems to not be able to start stream, it’s strange…
**Post date:** [May 25, 2017, 12:14pm UTC](https://forum.sierrawireless.com/t/bc127-auto-play-music/9216/3 "2017-05-25T12:14:42Z")
</div>
Update:
remote control from speaker by avrcp can pause stream but not play it. Maybe a stanby option is the cause?
**Post date:** [May 26, 2017, 12:36pm UTC](https://forum.sierrawireless.com/t/bc127-auto-play-music/9216/4 "2017-05-26T12:36:43Z")
</div>
Question :
When connected I have this notification : “LINK 10 CONNECTED A2DP xxxxxxxxxxxx SUSPENDED SBC SRC 48000”
The question is why a2dp is suspended at startup? it shouldn’t be? I tried with avrcp on or off…
**Author:** ![patrick23](https://avatars.discourse-cdn.com/v4/letter/p/76d3ee/32.png) [@patrick23](https://forum.sierrawireless.com/u/patrick23)\
**Post date:** [June 15, 2017, 11:08pm UTC](https://forum.sierrawireless.com/t/bc127-auto-play-music/9216/5 "2017-06-15T23:08:04Z")
</div>
I am having the same issue after upgrading from a previous version (6.0.32). On my sink device, I am able to stop the transmission but I am not able to start it using the same PIO. I am using a BC128, soldered onto a custom board. I updated to the latest Melody (6.1.4).
What I can do is manually enter MUSIC PLAY on my source device to enable the stream but this is unrealistic for my current application. I need a solution…
Thanks!
**Author:** ![tom](https://avatars.discourse-cdn.com/v4/letter/t/3d9bf3/32.png) [@tom](https://forum.sierrawireless.com/u/tom)\
**Post date:** [August 1, 2019, 4:03pm UTC](https://forum.sierrawireless.com/t/bc127-auto-play-music/9216/6 "2019-08-01T16:03:31Z")
</div>
I am using a B127-DISKIT board and have upgraded the firmware to version 7.3.
I am having the same issue.
Using the PLAY/PAUSE button (PIO 2) does not have any effect.
ENTERING MUSIC PLAY 11 returns OK, but not “AVRCP\_PLAY 11” and “A2DP\_STREAM\_START 10” I get when pushing the play button on my receiver.
Has anyone found a solution?
Thanks!
