BC127 - AT+CIND question
hi
my BC127 version 6.1.5
when i paired in AGHFP. (because i have to test AGHFP , A2DP -source )
PAIR_OK A8B9B3000B6B
AT 12 12 AT+BRSF=191
AT 12 11 AT+BAC=1,2
AT 12 10 AT+CIND=?
AT 12 9 AT_CIND?
AT 12 16 AT+CMER=3,0,0,1
OPEN_OK 12 AGHFP A8B9B3000B6B
i got AT-MESSAGE(AT+CIND=? / AT+CIND? ) from DUT(CAR H/U)
what message BC127 will return?
I just wanna know sequence of the descriptions .
thank you~ for reading
AT+CIND is a 3GPP command, you can download the latest spec for it at the link below.
http://www.3gpp.org/ftp/Specs/latest/Rel-15/27_series/27007-f00.zip
However, the format of the command is as follows.
+CIND: ,,,,
battery charge level (0-5)
0 low level
4 high level
5 means that the battery is charging (not supported)
signal quality (0-5)
0 low level signal
5 high level signal
service availability (0-1)
Message received (0-1)
call in progress (0-1)
Roaming indicator (0-1)
0 Home net
1 Roaming
SMS memory storage (0-1)
0 Memory available
1 Memory full
