# BC118 issues after baud change
**URL:** <https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376>\
**Category:** WiFi and Bluetooth Modules\
**Created:** [July 27, 2017, 11:41pm UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376 "2017-07-27T23:41:45Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![lalitb](https://avatars.discourse-cdn.com/v4/letter/l/53a042/32.png) [@lalitb](https://forum.sierrawireless.com/u/lalitb)\
**Post date:** [July 27, 2017, 11:41pm UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376/1 "2017-07-27T23:41:45Z")
</div>
I issued a command to the BC118 module to change the baud rate to 57600.
Since then the BLE module is not connecting. Each time I try to reset the module, it returns ERR.
I tried changing baud rate back to 9600, but no change. I also tried to connect via Melody Smart app to reload firmware but the app does not see the module.
I should also mention that this module is wired to my custom board. Its not a development board for evaluation.
Please advice.
Lalit
**Author:** ![mlw](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.sierrawireless.com/mlw/32/3706_2.png) [@mlw](https://forum.sierrawireless.com/u/mlw)\
**Post date:** [July 28, 2017, 7:26am UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376/2 "2017-07-28T07:26:33Z")
</div>
Lalit,
So if you are able to still send commands to the unit? This is implied but just want to make sure. If you do a scan either on your phone or from the BC118 do you see the other devices?
Can you send the following to the unit toget it back to a known good config and change it from there
```auto
rtr
wrt
rst
What was the command you sent to change the baud rate?
**Post date:** [July 28, 2017, 10:31pm UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376/3 "2017-07-28T22:31:16Z")
</div>
Hi Matt,
I tried the restore, write, and reset commands. But BC118 does not return either ERR or OK. I’m not seeing any reply back from the BLE module.
I used the UART=(BAUD) command to change the baud rate.
I issued
set uart=00eb
Lalit
**Post date:** [July 31, 2017, 12:41pm UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376/4 "2017-07-31T12:41:42Z")
</div>
Lalit,
I have just done the following
```auto
SET UART=00EB
WRT
RST
After the above I reset the terminal to 57600bps and it was communicating correcting at this baud rate.
I took it back to 9600 and tried setting it to 57600K again but did not send the WRT command before resetting it and it remained @ 9600, are you sure you are saving it and it is still not at 9600?
**Post date:** [August 3, 2017, 7:17pm UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376/5 "2017-08-03T19:17:45Z")
</div>
I suppose, I should have done a write and reset after changing the baud rate.
I added both of these commands and it worked. I then changed the baud rate back to 9600 then did a write and reset and it worked again.
Thanks for your help.
Lalit
**Post date:** [August 9, 2017, 11:09pm UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376/6 "2017-08-09T23:09:00Z")
</div>
Hello Matt,
I’ve run across another problem and I’m hoping have seen it before.
In testing I decided to test 2 different units which also have BC118 BLE modules.
The problem I ran across was that 1 of the newer units, only connect and allows me to configure the BLE when baud rate is at 9600. If I try to configure the module at 57600 baud rate then none of the commands (restore, write, reset) work. I always get back an error. But at 9600 it works fine. Have you run across a this problem?
Lalit
**Post date:** [August 15, 2017, 2:58pm UTC](https://forum.sierrawireless.com/t/bc118-issues-after-baud-change/9376/7 "2017-08-15T14:58:58Z")
</div>
Lalit,
What are you trying to change? Can you give me an example log from power up?
