# AT+WMFM - Inconsistent (and unhelpful) Behaviour
**URL:** <https://forum.sierrawireless.com/t/at-wmfm-inconsistent-and-unhelpful-behaviour/4605>\
**Category:** Around the water cooler\
**Created:** [August 10, 2010, 6:38am UTC](https://forum.sierrawireless.com/t/at-wmfm-inconsistent-and-unhelpful-behaviour/4605 "2010-08-10T06:38:11Z")\
**Showing post:** 1
**Author:** ![awneil](https://avatars.discourse-cdn.com/v4/letter/a/49beb7/32.png) [@awneil](https://forum.sierrawireless.com/u/awneil)\
**Post date:** [August 10, 2010, 6:38am UTC](https://forum.sierrawireless.com/t/at-wmfm-inconsistent-and-unhelpful-behaviour/4605/1 "2010-08-10T06:38:11Z")
All other AT commands (I think) will respond “OK” if the requested setting is already in place; eg.
- If you issue AT+WOPEN=1 (start application) when the app is already started, the response is “OK”
- If you issue AT+IPR=115200 (set baud rate) when the baud rate is already set to 115200, the response is “OK”
This all seems very good & reasonable to me.
But if you issue AT+WMFM to open/close a port when that port is already open/closed, it replies with “+CME ERROR: 3” 😠
This seems very Bad and Unhelpful to me - as it means that you then have to check whether the error is just due to the trivial reason (port already in requested state), or if it’s actually some real problem…
_[View the full topic](https://forum.sierrawireless.com/t/at-wmfm-inconsistent-and-unhelpful-behaviour/4605)._
