I have written a code to append the two buffers using wip_write at the client side.
The following is the code which I have written.
But its not appending the file at server side , its putting some junk values in to the file .
is there any other way to append the buffer …?
Kindly help to solve this prblem
case WIP_CEV_WRITE:
if(append==1){
int nwrite = wip_write( dst_data, buffer, sizeof( buffer) - offset); );// writing the first one
if( nwrite < 0) { /error/ return; }
offset += nwrite; /* Update the number of bytes sent. /
if( offset == sizeof( buffer)) { / All of [buffer] has been sent */
append=2;
offset=0;
wip_debug( "Done with the first one...\n");
if(append==2){
int nwrite = wip_write( dst_data, buffer2, sizeof( buffer) - offset[b]);// writing the second one[/b]
if( nwrite < 0) { /*error*/ return; }
offset += nwrite; /* Update the number of bytes sent. */
if( offset == sizeof( buffer)) { /* All of [buffer] has been sent */
wip_debug( "Done with second one\n");
append=1;
offset=0;
wip_close( dst_data); dst_data = NULL;
wip_close( dst_ftp_cx); dst_ftp_cx = NULL;
