ADL Event API
Hiya,
I’m trying to use the adl Event API to manage interaction between an ISR and a management task (as demonstrated in the uart_access sample application).
adl_eventWait() takes a bitmask with the event bits to wait on, and will wait for any (via ADL_EVENT_WAIT_ANY) of the event bits to be set elsewhere using a adl_eventSet() call.
What is not clear to me is how to work out which event bit was set when I am waiting on any one of a number of events to be set.
There is an option to pass in an outEventFlags variable to adl_eventWait(). I read (hoped?) that this variable would have the bit set according to which event had been set in the ISR, but my experimentation to date shows that it’s simply a copy of the inEventFlags mask (i.e. the event bit mask I am already waiting on). The return value from adl_eventWait() doesn’t give any hints either - the return value simply indicates the success or failure (and error code) of the function call.
How do I get which event bit was set after waiting on a call to adl_eventWait()?
Q2686/Open AT 2.37.6/FW 7.47.6
Thanks, Dave
Hiya,
I’ve misread the results of the adl_eventWait() call.
The outEventFlags variable to the adl_eventWait() call DOES return the event matched in the Wait - but this may not be a single bit depending on the value to the adl_eventSet() call…
ciao, Dave
